has anyone done this?
i have got a mk1 uno turbo 1301
the gear box is shot
so i got myself a little 22000 miles tipo 1.4 i.e which i am braking accept the gearbox and shafts ect
so i am wanting to put the gearbox in the uno, whats involved,. what do i need to change
the uno gearbox is bottom change
the tipo gearbox is top change like the later mk2 uno gearbox
so ive been told different things
im thinking i will definately need
gearbox - obviously
flywheel
starter
gear linkages which are rods not cables so its like the mk2 uno 1.4 setup
clutch
will i need to use driveshafts?
hubs?
gearstick?
mechanism at the bottom of gearstick?
if the box is hydrolic i will switch the clutch arm off the mk1 will it fit?
any info will be greatfully appreciated
heres the tipo gearbox selecter rods
gearbox - obviously
flywheel
starter
clutch
hubs?
gearstick?
