Ticking noise might be arcing between terminals on the distributor cap. Have a look when the engine is running in the dark - if you see bright blue flashes, take the cap off and clean/dry it, replace if cracked and check the spark plug leads for holes or splits.
If the engine is running smoothly it's probably not this problem and more likely to be the MAP sensor as lewey suggests.
-Alex
