Technical my turbo is playing up
Clean the fuel pump, change fuel filter to eliminate them. Check the boost hoses for splits etc. If its not these then could possibly be the Air flow meter. :)
a punto gt runs 1.2 bar standard and when you turn the boost up it doesnt jump all over the place it will just something the same.
abs light on punto gt
ive a punto gt that i just rebuilt and the abs light is on but when i had it on the snap on scanner it said fault "abs pump motor" but it was fine before i re shelled the car so any one sny ideas
well it does . it drives fine with no boost but wen it gets to 10psi on the boost gauge wen the boost is on it judders and jolts all about and can even jump all over the road ???????????
any ideas boys ????
No, the intercooler is fine as it is if the engine is still stanard. No need to introduce one of those unles you are going down the seb 4.1 route.
Get yourself on www.puntosports.co.uk
There are a few very knowledgable GT owners who i am sure will sort you out.
