My new front end :)
My new front end :)
imported_abyss113
Established member
well have had the HIDs and white sidelights for a while and was always hating the mixture of yellow from the foglights since they come on when you turn corners or indicate so had to do something about that
so have now replaced the foglights with some of the biggest LED setup youve seen :D
each bulb contains 68 leds :D but the result is amazing as can be seen here :)
[attachment=1:3cfb8av7]22082010035.jpg[/attachment:3cfb8av7]
just as much as standard really which is fine but since the front fogs on the bravos are 90% on all the time any way it was just to clean it up a bit and at night you can see a good bit with them but havent really done miuch driving with them yet to give a proper comparision for viewing distance
ill order some uv led sidelights and fogs and see what sort of tan i can get from them :D
