My beautiful 1.6 SX has started leaking.....any ideas please ?
N
Neil
Hi all,
My lovely Bravo has suddenly started leaking ! Damp, sodden carpet in passenger footwell after heavy rain..no dampness on seat, dash or via window seals that I can detect..drainage hole in engine compartement near screen are clear.. where is this coming from do you think ? going back to dealer next week...
Thanks, Neil
Untitled
Neil,
I haven't had this problem with my Bravo, but it was a perpertual one with my previous Renault 5GT Turbo. I eventually found that the rain was running down the window, past the window seal and into the door, where it was leaking out internally. When I opened the door panel, I found that the plastic sheet that covers the door had been removed at some point and not replaced. Putting in a new one solved the problem.
It's easy to check - just get a glass of water and run it down the outside of the window with the door open and see where it comes out!
Steve
Door
After polishing the door areas (what can i say - i like a clean car!) i have noticed a squeeky noise on both doors when pulling off my driveway (i am going somewhere with this). This suggests to me there is a lot of flexing going on, so i'm wondering - the sealing ability of the door rubbers may vary depending on where/how you park. Does it leak every time it rains ? Essentially I think Steve is probably right.
Sorry for boring the pants off you...
Cheers,
Grant
leaking sx
had the same problem with my 98' HLX finally traced the problem to a dislodged drain pipe behind the dashboard on the passenger side (don't know where it goes but when it leaks it drips about 1/2" away from the box of tricks behind the dashboard!!!! Like I said I don't know where the pipe goes so I haven't been able to reconnect it so I took the temporary measure of blocking the end of the pipe till I get a chance to get behind the dash!!!!!!! But so far theres been no more leaks (yet).
Leaking Bravo!
I have the same problem, but it was self inlicted. After removing the scuttle panel that covers the wiper motor etc. I discovered a week later that it is impossible to seal up. I still haven't cured it but I think new clips for the scuttle panel and at worst a run of silicone sealent will cure it!
S
1
7K
Streak2013
S
J
6K
J
M
7K
M
1
7K
Dark Lurker
