I swear this car should have come with complimentary supplies of valium for the many times it stresses me out.
My Multipla (2001 1.6 ELX) has packed up (again). Having driven me to my destination I left it overnight only to get in the next day for it not to start. Now strangely, whenever I am at this particular place the car always give a false message of "Brake Fluid Low - Stop Engine Contact Garage" when I first start up but goes off after 500 yards - the brake fluid is full; nowhere else do I get this message. So after the expected "Brake Fluid Low" message the car sounded healthy enough, trying to turn over but didn't.... and then the horrible Fiat warning beep came on and on each attempt at starting the "EBD-SYS FAULTY" warning alternated with "ABS-SYS FAULTY" warning message. I tried switching it off and then back on and then eventually tried disconnecting the negative from the battery before trying again, all to no avail.
So I was suddenly thankful that I had joined the AA (something else that should come as standard with the Mutlipla). On his arrival the nice AA man tried the car, looked under the bonnet and then done a diagnostic test. Strangely his computer found no reported faults on the car at all, despite the car's dash still reporting the "EBD" and "ABS" faults. So now my Multipla has slid another notch down in my affections and sits on my drive following AA recovery. It won't start at all and gives the same faults. Does anyone have a clue what I should do next?
Bearing in mind I have spent a small fortune on my Multi in the past when it lied and said I had a faulty injector - I got it replaced only to discover six months later the same thing happened again..... I drove on three cyclinders for about seven days and as if by magic, the car rectified itself and drove fine again with no fault reporting from the dash. Is there a reason why there should be seemingly random error messages from time to time? What can I do if there are no faults recorded when put on a diagnostic test? Apart from disconnecting the battery overnight, is there another way of completely resetting the whole ecu? And last question..... does anyone want to buy a Multipla??? 2001 1.6 ELX had a new clutch, new wishbone bush, new wheel bearings, new fuel injector, etc, etc.
