Technical Multiple misfires, stalling & unsure what it is?
Sean0402
London
Hey everyone,
I recently got a 500x 1.4 Multiair.
The car came with a few issues to start with. I have plugged my scanner in and receive the dreaded P0300. Multiple misfires on cylinders.
The car does stall & is extremely rough on idle. I did rev it a tiny bit one time and heard a loud noise from the exhaust & have not turned it on since as I need to try to solve this.
I seem to get similar error codes each time I delete them and start the engine up again for about 20-30 seconds.
P0300 & P130-A always stays though.
Fault codes which randomly occur are:
P0301
P0302
P0303
P0304
Understandable this will be true as it is unsure which cylinder it is.
So far I have replaced the following(Tired to keep as close to OEM as possible. Some are OEM, some are not.):
Battery
Coil Packs
Spark plugs,
Knock sensor (This made it run a tad smoother once replaced.)
MAP sensor
I currently have the injectors out and tested the resistance. Each are reading between 14.5 and 15. To my understanding, this is within tolerance. I have not been able to test the injector spray pattern as I do not have a machine.
I have also tested the wiring, everything is absolutely fine on that part. Voltage + resistance is all okay.
I am a bit stuck on where to look from here. Any advice would be greatly appreciated!
Model
500x 1.4 multiair
Year
2016
Mileage
79000
