Multipla  multipla owner
tommultipla1973
Hi New here. Have had a 2003 diesel multipla since August last year. Seems to be an ok motor. Recently serviced it and did the clutch. Looking at replacing the cambelt now so any tips or advice would be helpful :) thanks
Tom
If you can do a clutch on a multipla you can do any job on it, you are now fully qualified!
I did my cambelt recently, didnt change the water pump as many do, in fact I've changed 3 cambelts on multis and never changed the waterpump, never had a problem, yet..
Changing the water pump just makes it harder, I think you may need to remove the camshaft sprocket?
Anyway for the cambelt, used tippex, but have always found finding any sort of markings on the crank vague, so just use tippex on the old belt and dont move anything...but theres loads of info and some usefull pictures on this forum.
You may need some special tools like ribe to remove the engine mounting on the cambelt end, but removing the aux belt is easy, just by wrenching the tensioner back manually on its bolt head.
Good luck!
Cheers for the advice. I'm going to have to do the water pump as I suspect it's going.
Tom
