Does anyone know if the paid for version of multiecuscan will let me reset the oil change indicator on a 2008 1.9 diesel? I can't see any mention of it in the website.
Hi running in simulation there is no service reset for the 1.9 diesel Sedici. There is a oil change counter reset under the ECU if your car has a DPF.
The engine ECU is included in the "free" version so worth a try.
You could also try the "pedal Pushing" method but this is at your own risk.
1-turn on the ignition key,
2-press the accelerator pedal and hold it,
3-press the brake pedal 7 times without releasing the accelerator pedal,
4-keep pressing the accelerator pedal for 60sec.
5-Release the accelerator pedal and turn of the ignition key,
6- Wait for 60sec.
Then turn on the ignition key and start the engine. Check if the service/oil change light turned off.
