Does this sound worse then it looks or is it worth saving ? its been off the road for 2 Years which hasn't done it any favors
Repair immediately (major defects):
Offside Front Headlamp aim so that beam "kick up" is not visible on the screen (4.1.2 (a))
Offside Rear Sub-frame corroded and seriously weakened spring seat (5.3.3 (b) (i))
Offside Rear Upper Coil spring mounting corroded and seriously weakened box section (5.3.1 (b) (i))
Offside Rear Suspension component attachment bracket/mounting corroded and seriously weakened outer and inner sill (5.3.3 (b) (i))
Nearside Rear Suspension component attachment bracket/mounting corroded and seriously weakened outer/ inner sill (5.3.3 (b) (i))
Offside Rear Suspension component attachment bracket/mounting corroded and seriously weakened inner wheelarch to sill (5.3.3 (b) (i))
Nearside Rear Suspension component attachment bracket/mounting corroded and seriously weakened inner wheel arch and inner wheelarch to sill (5.3.3 (b) (i))
Central Rear Electrical wiring insulation so damaged or deteriorated it is likely to cause a short-circuit wiring below number plate not insulated (4.11 (c) (ii))
