I posted a few days ago about an irratic oil level sensor which at the moment seems to have sorted itself out but nnow have another problem.The red air bag warning light ,i assume this is the drivers side as turning off the passenger side only effects the orange indicator light .Ive checked the air bag connection at the steering column and all appears ok , ive also checked the passenger inhibit key switch just to make sure a cable hadnt come off there. I know i should take it to a dealer or auto elec but moneys tight and i want to eliminate any obvious problems before i do so , cna any body tell me
1. where the fuse/fuses are that control the airbag system
2. where is the sensor located that triggers the aire bags , is it located inside or outside the car . I only ask as this light only came on a short time after driving through a very large puddle.
3. Are there any relays in the airbag circuit and if so whre are these located.
4.Is it possible for myself to re set the ecu fault memory to see if the problem is still there,
any help in resolving this problem would be much appreciated . Come on lads help us out pls.
