Mk2b with Mk2 HID headlights..... is it possible?
simon_16vpunto1
Prominent member
I came up with the idea of fitting mk2 Headlight (the dipped headlight projector like bit) inside a Mk2b unit, then getting a HID kit off ebay and wiring it in.
The Mk2 bit would sit in the middle of the 2b Dipped headlight bit.
Would this be possible to do do you think?
Might give it a try some day cos i think it would look cool (Like Polo/ Lupo GTI's) when my car is going through its makeover when i get a mini
Or is it a stupid Idea?????
its hould be possible as all things are mods :) anything is possible with the right amount of money but im pretty sure that with HID lights you NEED to have front light washers or they are not road legal but dont quote me on that :)
'need to have washers' interesting, i dont thinks so as havent heard that anywhere else before but certainly worth checking with VOSA. Am sure someone on Boo would have pointed that out, due to the number of peeps who've removed there washers on the Barvo family. Not me though :D
As far as I believe there is no legal requirement for headlights to be washable no matter what type they are.
as i said dont quote me on it as cant remember :) but the peeps on BOO who have taken the washers off are standard lights anyway not HIDS
maybe im being silly, but why would u need washers with HID's as opposed to standard lights?
I think im gonna try this next year.
You get the kits off ebay for about £80 and they look cool as.
Im gonna rubber the idea of the Mk2 cowls inside the 2b unit cos getting the beam set right would be impossile and i wouldnt have a leveller
found this if it helps :)
And straight in from the Dept of Transport:
Quote:
Have received the following guidance from The Department of Transport.........
Dear Sir,
The situation for Gas Discharge (HID High Intensity Discharge) (commonly known as Xenon) headlamps is complex.
I attach links to the Road Vehicle Lighting Regulations 1989 which regulate the situation in the UK.
Under these Regulations Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
However you will be well aware that new vehicles have Xenon headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the Xenon headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
For the aftermarket, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "Xenon is banned in the aftermarket" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require Xenon in the aftermarket to meet the same safety standards as on new vehicles. The same level of safety should apply.
Therefore a Xenon headlamp sold in the aftermarket should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3, Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
Hope that helps.
We are aware of kit available in the aftermarket where a Xenon "burner" or bulb is fitted inside a headlamp designed for use with conventional Halogen filament bulbs. The burner is fitted with a "bayonet" type fitting so it fits where the Halogen bulb should fit. This is not legal and the vendor, the person who mounts it on the vehicle and the person who drives the vehicle are all committing an offence. (Which also means that he is invalidating the insurance.)
The reason for this is that headlamps and bulbs are made to tight tolerances and the wrong type of bulb will cause an incorrect beam pattern to be emitted, which could cause dazzle and discomfort to other drivers.
you know what they are like if they tell you its not legal they cant fine you if they catch you :) puts there xmas bonus out the window
