Technical MK1 Uno Turbo Brake upgrade
staffordshire
I want to upgrade the brakes on my Uno Turbo to Punto GT brakes, whats involved in doing this? is it just the discs and calipers? or anything else i need?
if it is just discs and calipers then seems a simple upgrade to me?
Mark,
Dont forget brake pads he he,, the punto gt calipers are hard to find but i did a cross check ages ago and they are the same as brava, bravo alfa etc barchetta, 1.8 and over with 252 vented discs so get to the scrappy Ant! and even bigger 20v marea and weekend, and coupe but will need 16in wheels
Not sure about the rear but the fronts should fit straight on. you'll need slightly longer hoses. Dedra/Tempra/Tipo 2L 8V are the same.
on a cinq, the GTs will bolt straight on. however, UT fronts will not. you need a 6mm spacer between the disc and hub... so makes sense to think that the GT calipers will need to be spaced 6mm backward to fit the UT?
From that it makes sence you will need to space the calipers out 6mm. Thats easily done. However, it maybe possible to find an easier solution, a different disc with a higher hat. Croma turbo have the same size rotors with a higher hat. try that.
