My mk1 uno turbo is drinking oil and miss fireing at top end, only happens in 5th gear after 5000rpm,
it only smokes when you boost it in 1st gear which is blue oil smoke, there is no smoke from start up from cold or even when starting and the engine is hot.
how ever when your in traffic and the engine is hot when you pull off it does cough blue oil smoke out,
it loses no water and the oil has not mixed,
I did a compression test today and all four cylinders were approx 140PSI.
anyone have an idea to the problem?
hope i can sort the problem out cause its going to be for sale soon as i am going to need a Van for work
