Technical Mk1 Turbo dash > 60s
uno du
I've bought Turbo dash, and install it in my '86 60s
Problem is rev counter, can someone help with the wires ? :worship:
Most of solutions are for Mk2 model...
This, from 'Chas Uno' is closest I find
' I have a mk1 Uno turbo instrument cluster that I've yet to fit to my 1986 Uno. Problem is, as Alex mentioned, a few of the gauges need extra sensors to make work in full.
As I have a mk1 SX instrument cluster fitted (with tacho, and I also swapped in the econometer from the 45S standard cluster), everything hooked up and worked no problem. The tacho just needed one extra wire from the low tension side of the coil, and I incorporated that into the multi pin plug for the dashboard'
On which pin it goes ?
The solution is . new wire from coil term. (1) to the righmost connector to dash (looking from seat), there are 6 wire places on it, and two of them are empty ('S' model). Now, looking from back side of instruments you need to connect new wire to second from left, and the rev is working !
