I've done a quick search on here but can't find anything, so I'll ask the question:
I've had a bit of a flat spot on my MJ Panda from about 1000 up to 1800 (peak torque) revs followed by a loss of power and an orange engine warning light coming on as you get to around 3000 rpm. under full throttle acceleration.
Having said that, it'll also suffer from a loss of power followed by the warning light at full throttle openings at around 2500 rpm in 4th or 5th.
When I originally had it diagnosed by my mechanic, the fault code read that it was a turbo pressure sensor valve (I think). He replaced it with an aftermarket part which lasted all of 20 miles. I took it back and he replaced it with a genuine part, which lasted around 100 miles before it went again.
Everbody I've spoken to who seems to know (sort of) what they're doing seems to think it's an ECU fault as on subsequent occasions when it's done the same thing the fault codes have been different, ranging from one that said the brakes were on while accelerating, they weren't and neither were the brake lights on, to a code that seems to have belonged on a Ford Focus.
I'm wondering if one of these ECU re-programming doofahs will do the trick instead. The car has so far covered 81,000 miles.
Any ideas?
Any ideas?
