Hello everyone. I'm new to the forum (well, newly registered they is
I've been reading a lot of posts on here).
I was hoping that maybe someone could help solve the mistery of my bravo 1.4 16v 2007. Car was working fine, no problem at all. Came back home from work, parked up and decided to replace the oil and filter. Finished adding the new oil, I installed a black box that the insurance company posted to me, attaching it to the OBD connector.
After that, I tried to start the car but it wouldn't start!
Was cranking but didn't start.
I take out the black box thinking it was the culprit, to no avail.
Get out the code reader, attached to the OBD and error code P0340 was shown. I replace the crankshaft sensor, still won't start. I checked the harness from sensor to ECU with a multimeter, cables is ok. Remove battery, short + and - battery cables for 10 min, re attached battery: code show now is p0335.
Replaced now camshaft sensor and check the harness fr sensor not ECU
Still not staring , persistent P0335 error.
Now I'm at the point where I start thinking out side the box: got out the timing tools, removed cambelt, readjusted the timing (aligning the command/valve system with the pistons/crank as per Fiat e-learn manual). Still no joy
My last effort would be to order a virginized ECU and see what happens next.
Any suggestions guys? Have I missed anything?
Thank you all very much in advance.
