car running fine stoped to un load boot .started ok then stated to missfire just got home.i replaced spark plugs and leads still misfires.dom i change coil packs.:bang:
If you swap the coils and the misfire follows the coils, the coils will be the issue. But you need to determine which cylinders are misfiring.
An alternative is to use an insulated tool to remove each lead, one at a time. The one(s) that don't affect the running speed of the engine are misfiring.
Logic suggests that a misfire caused by a coil will affect 2 cylinders.
