Technical Missfire on one cylinder
jb88
i was wondering if someone could help me
my cinquecento failed its MOT yesterday :bang:
as you can imagine i was not pleased...
the main problem that i am having is that the MOT inspector said that it was running on only three cylinders. because of this it had very high monoxide and hydrocarbons.
ive tried everything that i could think of.
ill list what i have tried
  1. New Spark Plugs
  2. HT leads
  3. Ignition Coil packs both replaced
  4. Had Head Gasket off - looks OK
apart from these any ideas why it is not working would be apreciated
jb88
edit: forgot to say its a 95ish bog standard 899 cc
Check for spark on all of the plugs.
Just because the tester said it's runnining on 3 doesn't mean he's actually right though ;)
What were your reading? any idea?
Kristian
My dad stuck his finger over each spark plug hole in turn whilst i turned the engine over. i do trust him because in a previous job he worked in a garage
jb88
Standard idol speed:
Co2 should be less than 0.300
actually is 0.476
hydrocarbons should be max of 300
my car is 467
and on the faster idol speed
Co2 should be 0.300
actually is 0.492
hydrocarbons should be max of 200
my car is 236
once again thanks for help given and a thanks in advance for any other help
jb88
Bah, thats nothing :D :p
Get yourself to Halfords, buy a bottle of Wynns Emissions reducer (purple bottle), stick it all in. Rag it for 20 mins before test to let it work through. Bet it goes through.
If not, then i'd look at the lambda. A missfire will not cause higher CO levels by that much, but with a missfire HC would be a lot higher. Looks like it may just be riching the mix too much imho.
Kristian
Well the thing is not only that it is that my car has a loss of power
i think this happened when i was driving, i stopped to go into a junction, clutch down, brake on, then stalled???? since then it has not been running correctly. it bounces a little when the accelerator is pressed down a bit and not sounding 100%
its just that its runable but it drinks the petrol like it's going out of fassion. its using about half as much petrol than it did before.
jb88
Well after a bit of tinkling we have my car running on all 4 almost
now it is a misfire
after 3 MOT Failures thats what we have decided
the emissions are still in the red
I have three options
1. Scrap it
2. Replace engine
3. a cylinder valve has been burned out
what are the chances of no 3???
if so how expencive would a new valve be and how hard would it be to replace the valve
this is because i don't want to spend out money on a new engine
and i don't really want to scrap it
the emissions are about the same as mentioned before except the hydrocarbons are over 500!!
any other possible solutions are welcome!
thanks for everyones help so far
jb88
On tuesday its goin into the guy who is in charge of the MOT center and he is gona do a compression test.
Well Thanks to all of you.
i got through the MOT yesterday.
i found the problem
it was a blown exhaust valve
£12.50 for a replacement and sailed through emissions test
once again thanks to everyone
jb88
Hmmm, I wonder what could have caused that?
An overly weak mixture is generally the cause of exhaust valves burning. Did the other valves look ok and was the head seat of that valve ok?
