last couple of days when I have started the car from cold [cinq sporting] it has misfired, and only ran on 3 cylinders for about 5 seconds, by which time the 4th fires ok
it then runs faultlessly from then on, if its left to go cold again that same day the problem doesnt reappear
water usage hasnt changed, I cant smell or feel anything like oil or petrol in the water, one thing I did notice, was if I filled the water to MAX, next time I check it its back between MIN and MAX, but never any lower
I would guess the compression is ok, as the engine idles very smoothly, engines with low comp on one cylinder tend to idle roughly.
I wondered if it might be a coil on its way out, but then would it make two cylinders misfire?
as I said, once running its fine, takes a while to get to temp, always has, mpg and power is great still, it never overheats - temp never goes over 90, the fan keeps a hat on it ok.
any ideas?
any ideas?
