coolhand_mike
- Joined
- Oct 6, 2004
- Messages
- 6
- Points
- 3
I am experiencing an annoying misfire/loss of power with my
Mk1 turbo between 3000-4000 rpm.
If I accelerate gently and progressively I get no misfire, but if I induce harder acceleration or am going uphill, a pronounced misfire cuts in.
It sounds like it’s only firing on 3 (and sometimes only on 2), and feels like
An ignition advance problem, the car juddering with the loss of power.
If I downchange 2 gears, when this is occurring, I put the revs above 4500 rpm and power returns, although a little flaky with slight popping.
The car is normal at idle and generally smooth in lower / higher revs.
I have fitted new Bosch plugs, 8mm silicon HT leads, dissy cap and rotor,
Ignition fuel relay, power module (not Marelli).
I suspect the power module but I would like to eliminate other possibilities.
The old ignition switch fell apart and I have fitted my own starter button arrangement with an aftermarket key switch, in the centre console.
I have noticed that the key gets quite hot, and I have wondered if the fault lies with the integrity of the key switch?
I have swapped ECU and coil, so I don’t think it is those.
the LT leads off the coil were flaky at the connectors, so I have replaced those also...no difference !
The exhaust is looking a bit sooty and I reckon the fuel use is a bit heavy.
I have uprated fuel pressure regulator and in-car boost adjuster, although I
am being very careful with it whilst problem persist.
Any Ideas ?
Any Ideas ?
