Hi all
My parents bought a converted ambulance, 2.5 1996 N reg, which had been partially converted for use as a camper.
Its not in the best state but heyho their money, and unfortunately it falls to me to sort out its niggles for them.
One of them is on one relay, all the wires have melted into one mass.
The relay has a green base, with 5 pins, 4 of which are used.
pin 87 - 2 orange wires
pin 85 - Blue/white wire
pin 30 - Orange & yellow/black wire
pin 86 - Orange/black wire
The relay is identical to all the others and I am unable to identify what circuit it is working with.
Any ideas?
Also, there is a blue relay that has been removed from a pink base. Any ideas what this one was used for?
Another question if I may?
As I say the Ducato is a converted ambulance (passenger tansport), and has side mounted scene light. This works if I power it directly so I know the light is fine. The wires to it have no power, but continuity is there, and the same issue is also at the switch, continuity but no power. No fuses that I can see have blown and I can't trace the wires any further than where they disappear travelling towards the engine bulkhead from the dash. It is completely baffling me
Annoyingly, everything vehicle related seems to be functioning ok, ie starts and drives etc, except that the keycode light is permantly lit
, but the little nitty gritty things that I can't get working are doing my head in :bang::bang:
Any help you can offer will be much appreciated
Any ideas?
