Technical  marea weekend.
barbel
wolverhampton
hi guys,
I'm thinking of replacing the rear drivers side door, has anyone done it before is it a fairly easy job to do.
doors are easily replaced, it is alinging the new one correctly that takes a bit more patience. use the height adjustment bolts on the hinges.
cheers jug,
I recently catched the handle on the drive gate which pushed the door in around the handle area. would you know if the dent will come out easy or would i do better just sticking a new door on as there are a couple on ebay.
thanks
Dave
most dents can be fixed easily, but it depends on the dent. if it woud require repainting then it sbes tot get a second hand door in the correct colour, its chepaer and the colour match is guaranteed.
