Marea Towbar (continued)
R
RM
Where can I buy I replacement hookup for the removeable towbar fixture?
It would appear that the kind dealer (ahem!) I bought my car off last year failed to hand it over.
Any help is appreciated.
Do you mean the eye hook that screws into the back/front of your car? If so, you can buy them from fit for around £4. Mine was missing too when I bought mine. I only found out after my clutch collapsed and it was needed to pull my car on the flatbed truck :(
Towbar
The towar on mine is a Bosal one, but I guess the only unique bit is the bit that bolts to the car - I would have thought the removable bit is generic.
Try contacting Bosal or a Bosal dealer, they should be able to help.
If you need it quick, a standard swan neck attachment can be bolted on in place of the stump the removable bit bolts on to. When i use my towbar I bolt a different bit on which is lower, then remove it when Im done - only takes a few minutes.
Re: Re: Marea Towbar (continued)
Fortunately I have the towing eye. My car is fitted with a removable towbar fixture, one where the fixture stays permanently attached and a towbar is slotted and locked into position when needed. Alas I haven't got the removable bit.
J
6K
J
S
3
1K
Stephen01
S
E
1K
E
M
1
820
Dark Lurker
