G
Gordon Smith
I have a 1999 Marea weekend 1.6 which intermittently refuses to start.
The engine turns over fine but just does not catch and these occurances are becoming more frequent. When it does eventually fire it runs smoothly.
Removing a plug when this happens shows a white deposit which I would have associated with fuel starvation or overheating.
Tried changing the plugs, then, as the fuel tank is always under suction, leaving the cap loose to see if the fuel was sucked out easier with no change.
I'm not familiar with the fuel system on this car, but there seems to be fuel in the pipe fixed to the bulkhead which I assume is the delivery, there also seem to be another two pipes in the engine compartment which head to the fuel tank but which are empty (of liquid) when opened at the quick disconnect junctions.
The car eventually starts if left for a while, anyone got any ideas what could be causing this? my next thought would be filter blockage or dodgy pump, but input from someone more knowledgeable than myself would be useful.
Thanks,
Gordon.
Thanks,
Gordon.
