Technical  Marea outdoor temperature sensor malfunction
heat
Odensbacken, Sweden
My outdoor temperature sensor is quite wierd.
When the temperature is +15 degrees Celsius, it shows anything between -25 to 0 degrees. :confused:
Is there anyone who knows where the sensor is located, how it is replaced, and if it is repaceble with any standard PTC or NTC-resistor?
/ Heat
Ps. Forgot to say that my Marea is a -01 model ( if it makes a difference)
I had problems with mine earlier this year, however it was about the same time that my battery started to go flat and required the occasional jump start. When I eventually changed it the temp readings went back to normal and have stayed like that since. Whether it was the battery or just that the battery was disconnected and it reset the ECU I'm not sure, all I do know is that it cured it.
Hope this helps
