Technical  MAREA instruments doesn't work
gawine
MAREA JTD
I realised that the instruments ( SPEED, fuel , temperature ,Tacho and kilometer counter)
isn't work. I checked the fuses , they are l good.
Could You help me ?
ThanX
Gawine
check the dashboard/front 20-pin connector continuity. Light blue-yellow wire is the main supply from power fuse box near engine, orange-white wire is from main switch to fuse & relay unit & this wire is looped to instrument panel by red wire. Yellow-black wire is the earth. Pls ignore this infor if its confusing!!!
