yuri
- Joined
- Aug 2, 2005
- Messages
- 57
- Points
- 12
Hello all,
i have been searching through the forum trying to find someone with the same problem as me, but i couldnt find any, so here is a new post. There are alot of posts about Marea's with injection light errors, but mine is a bit different.
For the record, i drive a late 1999 Marea 1,9 JTD with 140.000 on the clock. I have been driving with it for some time now, doing about 1200 km
Last week, when i tried to start the car, it didnt start. I was baffled, and thought it might be a battery problem. It wasnt that, cause after trying some time the engine started again. Some time before that i drove quite a bit, about 150 km. But, since the car started again, i didnt think anything from this, also because no error lights where lit.
Then after i again drove some kilometers (not much this time), the car lost power, and the red injection light came on. I couldnt start the engine after that. When i waited along side the road for some time, i could start the engine again, but after like 200 meters, it failed again. Again, with only the red injection light on.
My dad called a collegeau of him which has the same car, and he said it could be one of the four relays that reside just in front of the car's battery under the bonnet. We checked those, taking them out and cleaning them, and put them back. After that, the car started again, and i could drive normally.
Yesterday, when i drove the exact same traject as stated before, the car didnt start again. I was kinda getting pissed off, and did the same thing as before, taking out the relays. Car started again, and is running fine now...
I went to the local Fiat Dealer, and they told me its probably a problem with the temp sensor (sound logical) and they said i had to read out the engine for errors.
I just wanted to post this here, and maybe someone has any good advice, before i throw in money at the local dealer
Could it be the relays? One of them is the Fiat CODE relay.
Or is it most likely a faulty temp sensor, which doesnt let me turn on the engine because it thinks its too hot?
And, finally, could reading out the engine solve my problem?
Regards,
Yuri
Regards,
Yuri
