Marea engine timing
Marea engine timing
C
Colm
Hi - my 1.8 ELX Marea is ticking over a lot faster when idle (around 1500-2000 rpm) or alternatively revving back and forward between 1500-2200 rpm independently when sitting idle at traffic lights etc.
My mechanic cleaned out the valves and this has had a minor impact - the problem remains. Is this electrical by any chance (sunroof also has stopped opening!) - excuse the complete ignorance.
Throttle position sensor....
....is a common fault on these
Revving Marea
Hi, I had the same probs with my marea. It was the throttle idle valve and stepper motor! Just take it off, clean it with carb cleaner and a quick spray of wd40 before refitting. Hey presto no more revving!!
I did this two weeks ago and had no probs since then
Good luck!!!!!!!
J
6K
J
S
3
1K
Stephen01
S
E
1K
E
M
1
830
Dark Lurker
