Marea Centre Console Question
R
robban
Hello and greetings from a fellow bravo owner in Finland. Just wanted to ask what parts i need from a Marea to do the Marea->Bravo console conversion. Niether of the guides found her really tell what parts you need from the Marea. I know i need the console itself and the fabric that goes around the gear stick (dont know what you call it in English). But what else do i need?
Thanks!
kick plates in footwell, rear monting bracket and the pipes for the rear vent (if you want it to work)the arm rest obviously
everything else can be used from your bravo console i believe
Like anon said.
Marea Console - Including ashtray/vents, armrest, electric window switch panel, gearknob gator, handbrake gator, oddments tray rubber mat. Dont think the forward kickpanels are needed as i'm sure the Bravo ones fit better, but get them just in case.
Rear mounting bracket found under the ashtray once removed.
All heating pipes underneath - the forward parts will need to be modified to make the rear vent work.
All other brackets and screws will be the same.
S
3
1K
Stephen01
S
J
6K
J
E
1K
E
