marea centre console...look in
A
ACID
got offered one for about 30-40 maybe delivery included
anyway was told its the full consoel and mint
do i need to ask them anything else??
i took off my handbrake boot/gaitor for a customised one, and the pvc ridged one looked out of place
sicne then their is a gaping hole where the handbrake handle is
i was told a marea console will sort this and also provide me with an armrest.
is it tricky to fit, how many mins will it take?? do i take anythign out
please reply so i can tell the seller im instrested...
Ask for all the brackets and heating pipes that are under the console aswell (IMPORTANT). Also the little bits of trim forward the console (this may or maynot be needed). Fitting time is approx one hour. Your better off removing one front seat to fit. Also ask them you want the gear knob gator and knob, handbrake gator and the oddments tray cover.
Also £30 is alot of money. I paid £10 for mine, mint. I removed and collected myself.
Joske
its the best rice i have found
and i beliove he will thorw in the whoel works for 40 delviered..
still too much??
well as i said i cant find in any local scrappy..
if i could get hold of one, i would pay £40. go ahead mate, as you say its hard to find them
ade
yeh soudns it
cheers for the reply
thsi will now proivde me with an armrest
and cover the current hole where the orignal pvc handbrake boot/gaitor was....
also @ joske
why arent you ever logged in??
I'm never logged in because i come on and off the forum every few minutes. So hence can't be bothered to log in every few mins.
Just alittle advice with the fitting. If you get all the brackets with the console, then dont follow the guide on this forum.
Also you will need to adapt the air pipes under the console to work to the rear vents. If he sends you the console make sure you get the two narrow pieces of the heating pipes aswell. Then what you do is cut them the appropiate length and channel the air to the main pipe. Then tape up the pipes. Mine works perfectly.
Joske
Joske you no need to sign in each time, go to your account settings and select auto login for every quarter.
S
3
1K
Stephen01
S
J
6K
J
E
1K
E
