Right popped the MAF sensor off to give it a clean. It's not been done in about 10,000 miles. So did the deed using Loctite 7063. Put the sensor back in the housing and started it back up for the sensor relearn process.
Straight away the EML was light up. not a problem it usually stays on for a minute or 2 after a maf clean then goes out never to return. After 10 minutes of idleing the light was still on. The car is also not driving properly. Throttle responce and pick up from below 2k is bad below 1.5K is awful. There are also now occasional hot starting problems.
Now I have obviously broken my MAF. So the options are.
1, New from Fiat. Near 200 notes so as I've just lost my job thats a no.
2, New from the interweb. Price drops to around 40-50 but reports of bad quality. But do you really get bad quality electronics any more?
3, used. Are used MAFS a good idea? Also how is cross compatability between mafs and other cars? Will I only be able to use a maf from another VIS valver or because it's a Bosch part may it be possible it's fitted to other Fiats or even other manfacturers aswell?
It's becoming a pain to drive as I keep the revs higher so the MAF has less affect. Problem there is, well anyone who has seen and heard my car will know what the problem is. :evil:
