Technical Maf air temp sensor tested ok. Still shows fault
Gehngus
Wales
Hi Guys.
My 2010 ducato has engine light. Error is MAF air temperature fault.
This is the MAF with in built air temp sensor.
I have tested all the wires which are fine 12v 5v Earth 12v
So I swapped the maf sensor for a used. When I first put the replacement in it was fine for 30secondss. Thenstopped working again.
In multiuescan i can see the reading does not change. There is no signal.
If i move wires etc no difference so no broken wires.
So I then bought a new sensor. Just in case.
still no change. Still no signal.
I have tested the maf sensors with multimeter and hair dryer and they all seem to be fine? As in when warm them up, the resistance drops.
What have I missed?
Is there anything else that would mess this signal up?
Many thanks
bonjour,j'ai multiscan,il me semble qu'il te faut faire une reinitialisation avevc ton logiciel multiscan
