My cousin wants to swap the motor from is M3 (1993 Lreg), does anyone know if the 2002 Z3 engine will fit (also the 3.0 litre version only been modded to 343 bhp apparently
) would he need to change the ecu or not?
Surely just cheaper getting a E36 M3 lump?
How did it die in the first place?
Liam
i've just realise that you mean the 3.0 from a 2002 Z3 rather than the 3.2 from a 2002 M3 so its the S54B30 engine, but thats still very different to the old S50B30, for a start it has the 6 electric throttle bodies, an emisisons contorl systme that isnt present on the earlier car. the S54 range saw that posh gearbox that i believe can not be mated to the S50, so assuming vice verda is true then a new box is needed, and then you need to use magic to make the driveshafts fit (i doubt 2002 m3 shafts will because that used the 6 speed vs the Z3's 5 speed)
Most if not all BM's are RWD Jug.
Liam
