lowering a 500
lowering a 500
Like most cars, pee easy
Open bonnet
Jack chassis up (BOTH sides, makes it easier to fit as ARB wont be twisted)
Remove wheel
Remove strut bolts
Remove ARB drop link (if existent)
Remove strut turret mounting
Compress Spring
Remove strut top mounting
Remove spring
Refit in reverse :)
Rear:
Jack up chassis
Remove wheel
Remove bottom damper bolt
Pull out spring
Put new spring in
jack up rear axle
Fit the bottom damper bolt
refit wheel
(Do BOTH sides at the same time!)
REMEMBER AXLE STANDS!
