Hi
I'm restoring a nice fiat 126 from 99, polish origin. All the electrics works apart from the low beam.
I've checked that the main bulbs on both sides work (directly at a 12V battery). The fuses are OK. So I turn on the ignition, turn on the light switch at the left on the dash, and the parking lights come on. Front (small lights) and back are OK. Yet the lever from the steering wheel to activate the low beam doesn't work.
I've checked the schematics which I found here. Extracted the text for the legend and translated it into English. Checked the wires at the fuse box to see if they match the description and they do.
If I power the gray / gray-black wire directly at the fuse (position 3 and 4), both lights come on. The high beam with the green / green-black wires works as well, both direct and when pulling the lever towards the driver. So there's nothing wrong with the wiring or the bulbs or the fuses. It must be the steering column switch.
I read that their internal contact can go bad and the switch itself is not serviceable, so I ordered a new one which arrived today only to find that it's still not working!
If you look at the various wires on this switch, it's hard to see which ones are from the what. Yet, there's a yellow wire that has power. When you push the light lever towards the driver, the high beam comes on and the thick blue wire is powered (connecting it back to the fuse box, position 3).
The grey-red wire from this switch that connects back to the fuse position 5, which should power the low beams, does nothing, however the lever is changed. If I power the terminal of the grey-red wire directly, the low beam comes on. Same with the new switch! So it's not the internal contact but something different.....
What am I missing here?
I hope someone can shed some light and help me fix the last electrical problem.
Thanks in advance
Jeroen Brouwers
Thanks in advance
Jeroen Brouwers
- Model
- fiat 126
- Year
- 1999
