Technical Lights and indicators
Glendyson
Kent
Help please my nsf indicator won’t work checked bulb that’s ok , also i have no power to o/s dipped headlight i have read somewhere these are connected? Ducato 2007
Model
Ducato motorhome
Year
2007
Mileage
62000
Taking one thing at a time starting with the o/s dipped headlight. The fault must be fairly localised as both o/s and n/s are fed from the same relay but then via separate fuses. This would eliminate such things as the switch, BCM and relay circuitry. I have attached a diagram and the dipped headlight explantion.
  • dipped headlights.pdf
Thanks for the info both problems only started when i put the headlights back in after i had removed them for painting
