Thank you so much for this clear set of suggestions. Fog light is in the middle so happy days on that, will bring the van to the test centre as you suggested.I believe many european vans are set up for flat dipping, that is they dont dip to the right or left as in Uk (and eire?) take to the test station to ask, as may be acceptable as is or just to add tape in the correct place. or they may insist on new headlamps. Info from motorhome forums state over here it is variable what is acceptable (again in uk). Dont forget the rear fog lamp position, again in Uk it has to be in centre or right or both sides not left on its own.
Some of those headlamps have 2 positions for the bulb if it is a H4 just unclip and turn or flatten the edge to turn it.ThanksAirwave, mine is a semi integrated vehicle so its on a Fiat Chassis.
Current plan is to bring it to the CVRT and let them tell me what needs doing
Any, some good news, As its a 2021 van, it does not need a CVRT until 2025 so happy days re the lights for now.Some of those headlamps have 2 positions for the bulb if it is a H4 just unclip and turn or flatten the edge to turn it.
It may not need the CVRT until 2025, but it's probably still an offence if you're using headlamps that are aimed the wrong way and dazzle oncoming drivers.Any, some good news, As its a 2021 van, it does not need a CVRT until 2025 so happy days re the lights for now.
It only got clarified when I made a CVRT booking and they sent me the wrong fee, so I queried the fee to be told I don't need one till My 2025
I get that and I will have them looked at/ fixed etc, the issue was if it failed the CVRT, I only had 21 days to get it fixed, am heading to France in Sept for a spin so will get them sorted when I get back.It may not need the CVRT until 2025, but it's probably still an offence if you're using headlamps that are aimed the wrong way and dazzle oncoming drivers.
If it's 2021 probably has the H7 bulbs and there could be a cut out on the headlamp to move them to RHD.Any, some good news, As its a 2021 van, it does not need a CVRT until 2025 so happy days re the lights for now.
