The leisure battery on my 2002 Fiat Ducato is not charging. I have a new battery on order as the old one looks to be deep discharged.
I have identified the cable which feeds the charging current to the leisure battery at the battery end.
However I am struggling to find the other end of the cable in the engine compartment.
I understand the current will be fed via some kind of split charge relay, so if I can locate that then I should be able to check the relay and also the wiring.
I've attached a photo of that side of the engine compartment. Can anyone help spot the split charge relay in the picture? or give me an idea of what it looks like and any other possible location.
Many thanks
Many thanks
- Model
- Fiat Ducato
- Year
- 2002
