General Led no plate lamps
K333fer
Evening peeps I’m guessing this has probably been covered before but has anyone ever managed to get led bulbs in the no plate lamps that don’t put a warning up , have even tried with resistors and they just knock the no plate lamps out (50A 6ohm )
You do know that LED replacement lamps are illegal for road use?
For a resistor you would need aroud 28 ohms per lamp 27 ohms is a close standard value. Power rating needs to be at least 10W rating, but most get very hot at full power so I'd use 25W metal clad resistors.
Robert G8RPI.
