Technical  Leaking washer bottle
nuddmann
Sorted the fog light. Just found that the washer bottle appears to be leaking. The big clue being the washer fluid coming out of the bottom as I fill it!
I need to get it out to have a look but it disappears into the depths of the engine bay. There is an obvious bolt securing it at the top but I can't believe it's going to be that easy. Anyone got any tips?
Ok. So it's not the bottle leaking, which is just as well as it looks like you need to take half the front of the car off to get it out! It's the single outlet washer pump that feeds the headlamp washers. Ordered one off eBay but it's too small. I'm struggling to find the part number as there doesn't appear to be one printed on the part. The one off eBay is shorter and the inlet and outlet pipes are narrower than the original.
Anyone able to help?
Fiat Forum ePER is down (has been for a few days). Have you tried using one of the other copies of ePER available on line to look aup the part number?
EDIT: Just looked it up. For my car (2004 roundnose) it shows the pump as part no. 51736645
I have tried eper but to no avail. My car is the same year as yours, is the part no. You've quoted the pump for the headlamp washers?
That looks like the one. I spent ages looking on eBay how did you find that one!?
Anyway, have just sourced one from D A Motors for £15 delivered. At least the right one should turn up. What with that and a fog light, hitting that bloody badger the other day has not been cheap ?
