General Leaking Stilo...help
Browsing210
Hi...New to you all so hello.... have a bit of a problem..my lovely stilo is leaking!! Think windscreen problem..could be that a replacement (before my purchase) that has not been done correctly or missing a seal??? Bit concerned as dont have one around front windscreen but dont know if thats right!!!! :eek: Of course hadnt realised problem until this morning when the rain started!!! Any help would be greatly appreciated!!! :worship:
They are glued (bonded) in so no seal. Could have not been done properly. The glue has to be the right amount and spread evenly around the edge to make a seal. Too much and it squeezes out, too little and you get leaks. Also, I have seen people forget to put the primer on first, then the glue doesn't stick properly.
All windscreen replacement companies offer a guarantee. Get it checked/ rectified by them if it has not been done right.
Thanks very much...I will have a gander through the car info I got when bought it.... Many thanks
this happened to me recently. it looked wet around the right hand side of the screen, but actually it was a blocked drain channel in the skyport area. worth a look (if you have one)
