First I would check whether it is the bush at fault or the bolt that secures it rusted tight but not holding the bush tight in the mounting.
Get in there with a big pry bar and see where it is moving.
It may be a case of freeing up the nut and bolt, then either replacing or refitting the old bolt well lubricated and torqued up tight.
Remember there is a lot of weight on it so be careful.
