Technical Knocking noise on driverside suspension
DTstilo
Stirlingshire
I have a knocking noise on the driver side suspension.
This can be heard when the car is stationary and I turn the steering to the right. Sometimes it can be heard when I stop and turn the steering to the right when I reverse.
Anybody had the same problem. If so what is it? Is it bushes on front suspension?
I also have a bang noise from the rear when I go through pot holse. I read somewhere that it could be rear bushes that is warn.
:bang:
Front is probably a worn "Drop link" ...
https://www.fiatforum.com/stilo-gui...ur-drop-links-anti-roll-bar-links-30mins.html
Cheap and easy to fit.
http://www.ebay.co.uk/itm/200704174389
Rear is probably failed "rear axle bushes" ...
https://www.fiatforum.com/stilo-guides/269439-diy-stilo-rear-bush-replacement.html
This company(Manchester) sells the bushes and bolts(you'll need these) for £40, they also offer a fitting service "while you wait"(not sure how far North you are).
http://www.ebay.co.uk/itm/300675619298
However, I checked the drop links and they are fine. Any other sugestions as to what the cause could be.
Rear bushes - I will replace them in the next week or so.
:worship:
DT, i'm down in lanark if you ever pop down send me a PM and i'll investigate (having a few issues with mine but they are all getting sorted)
