Hello guys! Now I have recently purchased a new punto sporting and have again aquired a rear end knock, but only when going over bumpy roads. As in it isn't a constant knock, if I go on the motorway you don't hear a thing.
However, I'm positive it isn't the shocks as they look in good condition and the car dosen't bounce around when pushed. I've also checked the radial arm bearing as that has been a problem for me in the past but they again look fine and the arm's have no play in them. I have however found something inside the spring that seem's to have fluid on it. I believe it is called the 'Damper' but not too sure. Here's some picture's to show what I'm on about.
In the above image, highlighted in red is the part I'm talking about. This picture is on the other side as I can't get a clear shot of the dodgy one due to the exhaust being in the way.
In this image is the fluid I can see on said part.
Here's another image to help
All comments are appreciated. Thanks.
