where is the best place to get a new alarm fob for my bravo? my existing one sometimes doesnt work.could be a faulty switch????????? if i buy a new on , how will the codes match up?
Hi
I also bought an old key off ebay and have swapped swapped out the circuit board and one half of the cover (without the chip) but it doesn't work. Is there some sort of coding on the circuit board?
thanks
is there a chance you removed the immobiliser chip, and that the alarm chip(one with the code) is still on the board???i only changed the actual switch.everything else is original.if you have any problems, click on the link above, and give the guy a call. he was very helpful.hope it works out for you
aha - i thought the only chip was the black one up by the base of the key. I didn't realise there is another one on the board!!! that is actually the piece that is broken and gone missing on my board. it makes sense now. i will give the guy a call just in case he can help. thanks again
