vvatc
...that's how much I know about working on motors!
If anyone cares to recall from past posts, I had the motor rebuilt several months ago before shipping my 500 Giardiniera here to the U.S.
I've had a bit of trouble recently, and it came on rather suddenly. The motor is running very rough, as if it's misfiring. There's a slapping or slight popping noise and as the motor heats up, it gets worse and loses power. The distributor cap, rotor, points, condenser, plugs and plug wires are all only a few months old. Everything but the plugs look to be in good shape.
However, one of the spark plugs was very dark and looked fouled. So I replaced the plugs and the motor still runs rough. I tried to adjust the timing, but without a timing light, and without a mark on the engine & distributor to line up, it's a chore.
Then I thought maybe the plug wires are bad. So I disconnected the plug wire from the #2 cylinder. The motor started and ran, but a little bit more rough than before. Then I disconnected the #1 plug wire and the motor wouldn't even start?!?!?!
I haven't got up the nerve to try the old trick my father showed me to unplug a wire while the motor is running and hold it to the engine block to see if it makes a spark.
So, what in the world would cause the motor to run on one cylinder but not the other??
I remember my mechanic telling me that I would need a valve job in a few thousand kilometers after the motor rebuild. Could a valve on one cylinder be the cause? Would that come on that quickly? I'm a little hesitant to try and adjust the valves on my own. I'm sure it won't be difficult for a skilled mechanic...
Any input would be most appreciated...hopefully, I'm missing something ridiculously simple.
