Technical JTD Valve clearances
taken from the CD
Clearence in closed position
Exhaust 0.3 to 0.4mm
Intake 0.25 to 0.35
do we need to adjust this?
Shepherd said:
Does anyone know what the valve clearances are for the JTD 115bhp?
shepherd
Thanks for the info.
Yes we do need to adjust these. They are not hydraulic but adjustable, and they are included in the service schedule to be checked and adjusted if required.
What is the valve arrangement starting from the left cylinder (drivers side)? i.e. <in ex, ex in, in ex, ex in,> :confused: ??????????????
sorry cannot find any in the cd, do you mean the firing sequence
Hi there. the tappets are adjusted by measuring the gap under the lobe [pointing up], remove the shimm plate and fitting a thicker or thinner tappet shimm as required.special tool needed to hold bucket down while removing the shimm.........MP
