jtd low engine oil level light flashing
B
brava owner
hi there when i turn turn the key and all the warning lights come on , am i to wait for the low engine oil level light to go out as if i dont the light will flash for a few seconds when i start the engine.
the low engine oil level light will go out at about the same time as the airbag light does.
the engine is at the max oil level.
is there a problem with my engine???
(this light looks like a dip stick with a drop of oil coming off if and its red.)
The light indicates oil pressure, not level.
The light should go out within a few seconds of starting the engine. It will come on when you first turn the key as the engine is not running and hence there is no oil pressure.
It is the oil level light, only on JTD models, and it is behaving as it should. If you don't wait for it to go off, it will flash for a while but all's ok.
Pete
Re: Re: jtd low engine oil level light flashing
thanks for the comments
E
1K
E
I
2
1K
Dark Lurker
J
1
762
Dark Lurker
877
David
