Excerpt from the above thread:-
I did a rear brake job on her car a few months before the clutch failed so completely that dumping the clutch in first gear at idle would not kill the engine !
I wasted four days arguing with the dealer and VW and
got nowhere on behalf of my customer, arguing, of course, that this repair should be covered under the powertrain warranty as clearly outlined in the owner's manual.
Owner paid over $1300.00 for the repair and picked up her car.
The updated clutch (larger, new part number) was installed as far as I know.
One interesting omission is that neither the manufacturer of the DMF nor VW nor Bentley can come up with any specs for checking the DMF. I should know, I purchased the factory manual (worthless) and have sent emails to all partied mentioned above.
Below is info I posted on another forum:
Hopefully by now most? are aware that the 1.8T engines are experiencing more than their share of clutch failures.
Most are NOT aware that this engine uses a very unusual flywheel, that, IMHO, is at the root of the problem.
I had a customer's car, a 2001 Jetta 1.8T with only 15,000 miles and clutch went from working fine to failure (slipping so bad car will barely move) in the matter of one day. She has driven manual transmission cars all her life and got over 100,000 miles on the clutch disc in her last car (not a Jetta with 1.8T).
Why use a DMF (dual mass flywheel) ???
see:
http://www.luk.de/Bibliothek/D...s.pdf
For a good pic and info / TSB see:
http://www.sachshandel.de/owx_...2.pdf
Interestingly enough neither VW, Bentley, or Luk (who makes the DMF) have ANY info on specs or how to check the DMF.
Here is the final outcome of my customer's 2001 Jetta with the quick total clutch failure at 15,000 miles.
Dealer refused to honor this repair under the manufacturer's 10 year 100,000 miles Powertrain Warranty.
Here are the arguments that I suggested to the customer to pursue equity in this matter:
1) We demanded to be there upon removal of the transmission to ensure chain of command of all ruined parts. The transmission was removed without either one of us present and therefore we have no guarantee that any of the "bad" parts that were under her car ... were originally installed on her car.
2) The DMF (dual mass flywheel) found still bolted to the crankshaft was exhibiting play that exceeds that of a new unit. There is no specification in the factory repair manual and neither Bentley, Audi, nor LuK has been able to come up with one. ... but a new DMF I tested had 6mm play. The one on her car had more than 22mm play ! Maybe even more important is that oil / grease appears to have leaked out from the DMF and contaminated the clutch disc and the whole inside of the bell housing.
3) The whole unit is under-engineered. The new part number for the upgraded unit is 17-059 (LuK) and 06A 105 264M (VW). This upgraded unit has a larger (230mm v 220mm OD) clutch disc. Hopefully they will not wear out so quickly !
4) There are many reports of early catastrophic clutch failures for VW DMF cars .. on the internet.
5) Key personnel at the dealer and at the company that manufactures the clutch units have confirmed several times the abnormal failure rate of this clutch unit, especially in 2000 and 2001 Jettas with 1.8 Turbo engines.
6) Just to the left of the input shaft to the transmission was an abnormal wear pattern on a static surface of the tranny that should not be there. I believe that the bolts holding the pressure plate to the flywheel either broke or worked loose and allowed excessive movement of the pressure palte to contact the inside static surface of the transmission housing. This is completely abnormal ..... Once again .... since they did not allow me to be there during teardown.... we can only assume they wish to hide something. At this point I can not confirm my assertion since I do not even know where the bolts are now .......
7)VW of NA customer service has been of absolutely no assistance in this matter. They refused to advance this issue to the District Tech Rep. The customer has paid for the repair (over $1300) and picked up her car. We anticipate that a lawsuit (very possibly a class action) will be necessary in order for equity to prevail.
Advice: do not buy a VW with a 1.8 turbo engine, it has a DMF.
